2 Pages12>
Robert71
#1 Posted : Wednesday, August 20, 2008 12:49:44 PM(UTC)
Robert71
My Maytag washer and dryer are just about 4 years old.I encountered my first problem since new today.The washer gets stuck between the 9-10 minutes mark and will not do anything but stay there.It does not shut off just freewheels at that mark.I tried to research this problem through the archives here but did not find anything with this particular model and problem.Thanks in advance.
Robert71
#2 Posted : Thursday, August 21, 2008 1:01:14 PM(UTC)
Robert71
Anyone? Shall I run it again and watch it through the whole cycle?
libertyappl
#3 Posted : Thursday, August 21, 2008 1:11:57 PM(UTC)
libertyappl
Question....What do you have in the washer?
nat
Robert71
#4 Posted : Thursday, August 21, 2008 4:14:37 PM(UTC)
Robert71
I had a load of jeans and shirts.It did not spin out but I have an older set down stairs I used to finish the job.What would you suggest I load it with?
#5 Posted : Friday, August 22, 2008 3:51:54 PM(UTC)
Hi Robert,
Look for the tech sheets inside the control panel and perform all tests recommended by the manufacturer. Post the results.
libertyappl
#6 Posted : Friday, August 22, 2008 6:46:02 PM(UTC)
libertyappl
Just a lot of time the weight of the load can't balance that's exactly what it will do. I have one of these and have to watch washing blankets. quilts etc.
Robert71
#7 Posted : Wednesday, August 27, 2008 10:55:17 AM(UTC)
Robert71
Hi Robert,
Gene,where is the control panel?? I looked for it on here and didnt find it.I ran it again today and pretty much the same happened.Its stuck in the drain cycle,repeating it over again and wont go into spin.
#8 Posted : Wednesday, August 27, 2008 11:44:06 AM(UTC)
Very possible the problem with your washer described in this Maytag Technical Bulletin.
The control panel aka console (#1 on the break down diagram).
Robert71
#9 Posted : Wednesday, August 27, 2008 12:42:56 PM(UTC)
Robert71
If it is what is described in the service builitin,is that something I can tackle or should a technition be called.
#10 Posted : Wednesday, August 27, 2008 1:18:09 PM(UTC)
Robert,
Nobody knows it better than you.
GE washer Problems w/ Agitation GCWN3000M1WS (Washer Repair)
by ps33 12/19/2020 4:19:13 PM(UTC)
Kenmore VMW 22352 Washer Problems (Washer Repair)
by Papa_omero 3/11/2019 5:25:53 PM(UTC)
Whirlpool Duet Sport Washer problems (Washer Repair)
by bdmbluegrass 1/11/2017 11:54:22 AM(UTC)
washer problems (Washer Repair)
by porterbridges 1/18/2015 10:53:23 AM(UTC)
by Revelation320 9/4/2013 4:41:04 PM(UTC)
Commerical Washer Problems (Washer Repair)
by sherryash 12/18/2012 3:11:25 PM(UTC)
by mariela 10/24/2012 7:44:31 PM(UTC)
Bosch Dishwasher problems (Dishwasher Repair)
by Manuel Arce 9/15/2012 9:14:41 AM(UTC)
Whirlpool dishwasher Problems (Dishwasher Repair)
by captbud 8/1/2012 10:21:44 AM(UTC)
by malon66 6/21/2012 6:17:18 PM(UTC)
WP Ultimate Care 2 washer problems...new timer didn't fix (Washer Repair)
by HunterTinsley 4/6/2012 6:11:49 PM(UTC)
Whirlpool Washer Problems (Washer Repair)
by GK12 3/4/2012 1:28:37 PM(UTC)
LG Dishwasher problems HELP! (Dishwasher Repair)
by djmcheme 11/19/2011 11:05:29 AM(UTC)
Intermittent washer problems (Washer Repair)
by rscha787 10/12/2011 5:56:35 PM(UTC)
by jamesnl 10/9/2011 2:13:43 PM(UTC)
2 Pages12>
