I have a Magtag Dryer,It wont heat up...it just blows cold air, is there anywhere I can get a diagram so we can find out what the problem is... Thank you in advance for any help, or if possible does anyone have any ideas what can be wrong with it
Groups: Expert
Sounds like the heater may be bad or the thermal fuse but when the thermel fuse is bad it usually don't start at all.
