kramler92
#1 Posted : Thursday, December 8, 2011 3:14:26 PM(UTC)
kramler92
My maytag neptune dryer heats up for about 20 seconds with the gas and then stops. it doesn't heat up again after that. what is the problem?
ApplianceJunk
#2 Posted : Thursday, December 8, 2011 3:42:58 PM(UTC)
ApplianceJunk
One of the two coils on the gas valve maybe failing.
kramler92
#3 Posted : Thursday, December 8, 2011 3:56:10 PM(UTC)
kramler92
Where is the coils and how do I check which one of any are failing
ApplianceJunk
#4 Posted : Thursday, December 8, 2011 4:02:00 PM(UTC)
ApplianceJunk
The coils are located on the gas valve. I would replace them both at the same time. You can order them as a set. They are cheap and easy to replace. Here is the service manual for this model dryer. It will tell you everything you need to know.
http://appliancejunk.com...wnloads;sa=view;down=386
btw, did you ever get the dryer working from your other topic.
http://forum.appliancepartspros...ts-error.html#post616215
You seem to be having your fair share of dryer problems. ;)
kramler92
#5 Posted : Thursday, December 8, 2011 4:06:16 PM(UTC)
kramler92
Yes I did fix the ts error! I'm learning as I go tho ha. But I will try fixing the coils thanks
ApplianceJunk
#6 Posted : Thursday, December 8, 2011 4:13:37 PM(UTC)
ApplianceJunk
Your welcome, let us know how it turns out.
kramler92
#7 Posted : Thursday, December 8, 2011 4:14:13 PM(UTC)
kramler92
oops i had the wrong model number that one is for my washer which has a leak! but the right model number is MDG9700AWW
ApplianceJunk
#8 Posted : Thursday, December 8, 2011 4:25:48 PM(UTC)
ApplianceJunk
Then this is the service manual you will want. :)
http://appliancejunk.com...ownloads;sa=view;down=69
kramler92
#9 Posted : Thursday, December 8, 2011 4:34:36 PM(UTC)
kramler92
so this is what I found:
The gas is ignited but the flame goes out. If a
normal ignition takes place and after a short while the
flame goes out, check for the following:
• Radiant sensor contacts opening
prematurely.
• Weak gas valve coil may open when
stressed by higher temperatures.
• Weak Hi-Limit
• Poor venting
• Bad drum seals
you think its the coils? am I supposed to replace the 2 coils on the gas valve assembly?
ApplianceJunk
#10 Posted : Thursday, December 8, 2011 5:20:13 PM(UTC)
ApplianceJunk
It could be the coils, here is some more info on testing the coils.
http://appliancejunk.com...t-dryer-gas-valve-coils/
Sometimes they can be hard to test because they may test fine when the unit is cold.
Whirlpool Imperial series gas dryer wont heat up.. (Dryer Repair)
by NBK 4/6/2009 3:36:45 PM(UTC)
Gas dryer wont heat up (Dryer Repair)
by yertle11 1/7/2009 7:01:50 PM(UTC)
