kramler92
#1 Posted : Thursday, December 8, 2011 3:14:26 PM(UTC)
kramler92
My maytag neptune dryer heats up for about 20 seconds with the gas and then stops. it doesn't heat up again after that. what is the problem?
ApplianceJunk
#2 Posted : Thursday, December 8, 2011 3:42:58 PM(UTC)
ApplianceJunk
One of the two coils on the gas valve maybe failing.
kramler92
#3 Posted : Thursday, December 8, 2011 3:56:10 PM(UTC)
kramler92
Where is the coils and how do I check which one of any are failing
ApplianceJunk
#4 Posted : Thursday, December 8, 2011 4:02:00 PM(UTC)
ApplianceJunk
The coils are located on the gas valve. I would replace them both at the same time. You can order them as a set. They are cheap and easy to replace. Here is the service manual for this model dryer. It will tell you everything you need to know.
http://appliancejunk.com...wnloads;sa=view;down=386
btw, did you ever get the dryer working from your other topic.
http://forum.appliancepartspros...ts-error.html#post616215
You seem to be having your fair share of dryer problems. ;)
kramler92
#5 Posted : Thursday, December 8, 2011 4:06:16 PM(UTC)
kramler92
Yes I did fix the ts error! I'm learning as I go tho ha. But I will try fixing the coils thanks
ApplianceJunk
#6 Posted : Thursday, December 8, 2011 4:13:37 PM(UTC)
ApplianceJunk
Your welcome, let us know how it turns out.
kramler92
#7 Posted : Thursday, December 8, 2011 4:14:13 PM(UTC)
kramler92
oops i had the wrong model number that one is for my washer which has a leak! but the right model number is MDG9700AWW
ApplianceJunk
#8 Posted : Thursday, December 8, 2011 4:25:48 PM(UTC)
ApplianceJunk
Then this is the service manual you will want. :)
http://appliancejunk.com...ownloads;sa=view;down=69
kramler92
#9 Posted : Thursday, December 8, 2011 4:34:36 PM(UTC)
kramler92
so this is what I found:
The gas is ignited but the flame goes out. If a
normal ignition takes place and after a short while the
flame goes out, check for the following:
• Radiant sensor contacts opening
prematurely.
• Weak gas valve coil may open when
stressed by higher temperatures.
• Weak Hi-Limit
• Poor venting
• Bad drum seals
you think its the coils? am I supposed to replace the 2 coils on the gas valve assembly?
ApplianceJunk
#10 Posted : Thursday, December 8, 2011 5:20:13 PM(UTC)
ApplianceJunk
It could be the coils, here is some more info on testing the coils.
http://appliancejunk.com...t-dryer-gas-valve-coils/
Sometimes they can be hard to test because they may test fine when the unit is cold.
Guest (6)
Whirlpool Imperial series gas dryer wont heat up.. (Dryer Repair)
by NBK 4/6/2009 3:36:45 PM(UTC)
Gas dryer wont heat up (Dryer Repair)
by yertle11 1/7/2009 7:01:50 PM(UTC)
