johns problem
#1 Posted : Wednesday, June 30, 2010 4:34:12 PM(UTC)
johns problem
Replaced thermal fuse 2 months ago. Same problem again. Received new part and installed. Won't run.....Metered all parts on heating element board..all o.k. Can't find any disconnected wires, breaker is good, all pluged in.....stumped
John Van
#2 Posted : Thursday, July 1, 2010 7:30:39 AM(UTC)
I cannot find a wiring diagram for this unit so can olny give general info.
[COLOR="Blue"]Won't run.....[/COLOR]
I am assuming that the motor will not start.
[COLOR="Blue"]Metered all parts on heating element board..all o.k.[/COLOR]
The only device in the heating area that will stop the motor from running is the thermal fuse usually mounted on the blower assembly.
Have you tried flipping the breaker off/on a couple times. Sometimes you can loose half the line or Neutral without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Other things to check would be the door switch and the push-to-start switch.
When you replaced it did you clean/check the vent system and the blower wheel.
Something cause it to go a second time.
If yes then it could be your motor was going south, running slower and the lower air flow blew the thermal fuse. Perhaps it has finally given up the ghost.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Amana dryer motor growl at startup (Dryer Repair)
by Guest 9/21/2023 3:35:28 AM(UTC)
Amana Dryer (NED4600YQ1) Heating Element not heating (Dryer Repair)
by vckiran1 12/29/2019 6:06:10 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Amana dryer flipping breaker (Dryer Repair)
by Wumford 8/13/2016 12:43:25 PM(UTC)
Amana Dryer Error Code TS (Dryer Repair)
by DaleW 7/14/2016 6:47:27 AM(UTC)
Amana dryer will not shut off on automatic cycles (Dryer Repair)
by Nutforbriggs 4/21/2016 11:42:33 AM(UTC)
Amana Dryer NED7200TW Not Drying/Heating Up (Dryer Repair)
by Bappy 4/6/2015 3:40:10 PM(UTC)
AMANA dryer runs continuously on automatic cycles (Dryer Repair)
by crussev 7/17/2014 5:23:43 AM(UTC)
Amana Dryer Dead (Dryer Repair)
by Jonas76 7/2/2014 5:29:02 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
Amana Dryer won't heat (Dryer Repair)
by bangacan 11/28/2013 10:57:32 AM(UTC)
Amana Dryer keeps blowing thermostat (Dryer Repair)
by dfrye 11/27/2013 6:56:02 PM(UTC)
