Service Tech, Replace With A 3 In 1 Starter Kit Ayear Ago. Work Fine And Last A Year.stop Freezing And Cooling,i Myself Replace It With A 3 In 1 Starter Kit,but This Time The Compressor Will Not Start,just Clicking Noise,compress0r Feels Warm. The Fan Is Running
Did the servicer also wire in the run capacitor if there was one, usually mounted near the compressor? Also, using a 3n1 hard start device usually burns out the compressor, particularly the modern, low horsepower ones. If it now fails to start, the start winding in the compressor is probably blown out.
I Want To Thank You Richappy For The Info,i Don't Know About The Wire In The Run Capacitor If He Did That.at This Point If The Winding Is Blown Out Do You Have Any Suggestion In What Should I Do At This Time. Thank You, Cool
