Blake1111
#1 Posted : Wednesday, June 23, 2010 3:03:16 PM(UTC)
Blake1111
This front loader will spin at high speed with tub empty or with a light dry load in it.Any weight in the tub no matter how small and it will tumble like its washing than go to a low spin, than back to a tumble. It never goes to high spin.
sidfink43
#2 Posted : Friday, June 25, 2010 10:49:41 AM(UTC)
sidfink43
Interesting problem.
Use this service manual to check the speed control board, and to see if you can put it in a diagnosis mode and generate some error codes. If you cannot find anything else wrong try replacing the speed control board as that is the most likely (but not certain) problem.
http://frigidaireservicetips.co...AffinityWasherManual.pdf
Frigidaire washer not draining, no high speed spin (Washer Repair)
by Stheemka 3/24/2020 6:39:56 AM(UTC)
No high speed spin - E58 (Washer Repair)
by bobw462 10/5/2014 6:25:12 PM(UTC)
No high speed spin (Washer Repair)
by Motorat 9/13/2013 9:40:27 PM(UTC)
no high speed spin (leaves things too wet) (Washer Repair)
by sgm1115 1/28/2013 4:32:34 PM(UTC)
by surferfletch 1/14/2010 2:52:04 PM(UTC)
by DEEDEEGOGO 10/15/2009 11:49:33 AM(UTC)
Kenmore Front Load Washer - No High Speed Spin (Washer Repair)
by BLKJAK 10/13/2009 7:36:26 PM(UTC)
Front loader no high speed spin (Washer Repair)
by richappy 9/29/2009 1:44:47 PM(UTC)
