This front loader will spin at high speed with tub empty or with a light dry load in it.Any weight in the tub no matter how small and it will tumble like its washing than go to a low spin, than back to a tumble. It never goes to high spin.
Interesting problem. Use this service manual to check the speed control board, and to see if you can put it in a diagnosis mode and generate some error codes. If you cannot find anything else wrong try replacing the speed control board as that is the most likely (but not certain) problem. http://frigidaireservicetips.co...AffinityWasherManual.pdf
