Washer is not spinning. I checked the coupler, it's good. The drive block is good. The lid switch is good. I had the cabinet off and turned the washer on in the spin cycle, this is what I observed: the motor spins, the coupler spins, the clutch spinning. The basket did not spin. I tried to assist the basket and it moved and stopped. Do I have a bad basket drive or a bad gearcase? Is there a way to verify which item is bad? Your help would be great.
Thanks, Oscar
Oscar,
It could be a bad clutch as well as a bad basket drive. You have to remove the gear case from the washer and remove the clutch from the gear case and inspect the clutch and the basket drive.
Gene,
Thanks for the assistance. I will replace the basket drive assembly (comes with new clutch).
Oscar
