Oscar
#1 Posted : Thursday, July 17, 2008 7:46:18 AM(UTC)
Oscar
Washer is not spinning. I checked the coupler, it's good. The drive block is good. The lid switch is good. I had the cabinet off and turned the washer on in the spin cycle, this is what I observed: the motor spins, the coupler spins, the clutch spinning. The basket did not spin. I tried to assist the basket and it moved and stopped. Do I have a bad basket drive or a bad gearcase? Is there a way to verify which item is bad? Your help would be great.
Thanks,
Oscar
#2 Posted : Thursday, July 17, 2008 4:27:47 PM(UTC)
Oscar,
It could be a bad clutch as well as a bad basket drive. You have to remove the gear case from the washer and remove the clutch from the gear case and inspect the clutch and the basket drive.
Oscar
#3 Posted : Thursday, July 17, 2008 5:45:52 PM(UTC)
Oscar
Gene,
Thanks for the assistance. I will replace the basket drive assembly (comes with new clutch).
Oscar
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
MAYTAG NEPTUNE STACKED - GAS - NOT SPINNING (Washer Repair)
by ccalderon70 1/9/2023 9:09:40 AM(UTC)
Kenmore Elite HE3 not heating and drum not spinning (Dryer Repair)
by Guest 12/23/2022 11:32:17 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
Buzzing and not spinning (Washer Repair)
by sweetac100 11/22/2022 2:50:16 PM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Whirlpoool Duet not spinning clothes dry (Washer Repair)
by AdamsBT1 4/9/2022 6:03:49 AM(UTC)
Ge washer tub not spinning (Washer Repair)
by Rconner86 3/17/2022 7:32:41 PM(UTC)
Maytag MTW5770TQ) Draining but not spinning (Washer Repair)
by cj2874 2/6/2022 3:54:15 PM(UTC)
Whirlpool WTW4950xw0 not spinning, draining (Washer Repair)
by webdiva20 12/29/2021 10:43:20 AM(UTC)
LG washer -Drum not spinning during rinse cycle with Fe error code (Washer Repair)
by Guest 12/29/2021 3:31:30 AM(UTC)
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
