rklassen
#1 Posted : Friday, June 19, 2009 9:55:28 AM(UTC)
rklassen
My Bosch dishwasher, model number SHU33A02UC/17 is not emptying the tub after a load has gone thru the wash cycle. That said I've exposed the impeller at the bottom of the sump and it does not spin easily. I'm thinking the pump needs replacing. Can anyone help me with instructions for getting at the pump and changing it out. I'd like to do it without breaking anything.
#2 Posted : Friday, June 19, 2009 3:31:43 PM(UTC)
The instructions are attached to the reply.
- The part number for the drain pump is AP2802385
File Attachment(s):
Drain pump removal.doc (630kb) downloaded 36 time(s).
rklassen
#3 Posted : Tuesday, June 23, 2009 2:05:34 PM(UTC)
rklassen
Gene,
Thanks for your help.
I've changed the pump and the first cycle I ran seemed to go okay. Now, however, it appears I'm not getting water into the machine. What do you think has gone wrong?
Ron
Whirlpool Soft II Off Balance After Pump Replacement (Washer Repair)
by FloozyALaMode 5/2/2017 1:08:36 PM(UTC)
Maytag Neptune still not draining fully after drain pump replacement (Washer Repair)
by wrboozer 8/3/2014 7:59:42 AM(UTC)
Washer pump replacement (Washer Repair)
by garygordon 10/6/2011 3:45:40 PM(UTC)
by garygordon 10/6/2011 3:40:35 PM(UTC)
Bosch Nexxt 500 Washer Pump Replacement (Washer Repair)
by eblum 8/8/2011 8:32:13 AM(UTC)
water pump replacement (Washer Repair)
by rhlhomes 6/2/2011 7:40:37 AM(UTC)
by tim l 3/29/2011 5:27:48 PM(UTC)
LG Washer Pump Replacement Procedure (Washer Repair)
by dz63 3/15/2011 3:33:18 PM(UTC)
Motor and Pump replacement (Dishwasher Repair)
by fixinmydishwasher 3/9/2011 11:45:19 AM(UTC)
kenmore HE pump replacement (Washer Repair)
by ronco05 3/3/2011 1:14:40 PM(UTC)
Drain Pump Replacement (Dishwasher Repair)
by resurface 1/18/2011 11:08:18 AM(UTC)
Humming Whirlpool - what motor & pump replacement parts do I need & HOW do I do it ? (Dishwasher Repair)
by dishwasher hums 12/31/2010 8:55:16 AM(UTC)
Amana Washer Assey Pump Replacement (Washer Repair)
by Chris10379 10/15/2010 3:36:36 PM(UTC)
Whirlpool dishwasher motor pump replacement (Dishwasher Repair)
by suzieQ5 7/31/2010 9:23:03 PM(UTC)
GE Washer Pump Replacement (Washer Repair)
by zakinsfbay 5/19/2010 9:05:37 AM(UTC)
