garygordon
#1 Posted : Thursday, October 6, 2011 3:45:40 PM(UTC)
garygordon
how do you remove and replace the washer pump? I have the front cover off and can see the pump
Jeff / APP Team
#2 Posted : Friday, October 7, 2011 7:27:14 AM(UTC)
Jeff / APP Team
Hello. You will need to remove the belt from the large pulley. Then remove the wires going to the motor. Now remove the bolts holding the motor support in place and remove the motor and pump from the washer. Remove the three screws securing the pump the the motor shaft. Reinstall in reverse order with the new pump assembly. Hope this helps.
Part number: AP4036191
Washer pump replacement (Washer Repair)
by garygordon 10/6/2011 3:40:35 PM(UTC)
Bosch Nexxt 500 Washer Pump Replacement (Washer Repair)
by eblum 8/8/2011 8:32:13 AM(UTC)
LG Washer Pump Replacement Procedure (Washer Repair)
by dz63 3/15/2011 3:33:18 PM(UTC)
GE Washer Pump Replacement (Washer Repair)
by zakinsfbay 5/19/2010 9:05:37 AM(UTC)
Bosch Washer Pump Replacement (Washer Repair)
by ray ernst 10/18/2008 9:37:32 PM(UTC)
Dishwasher Pump Replacement/Cleanout (Dishwasher Repair)
by Ed De Meter 1/5/2008 9:07:40 AM(UTC)
