ronco05
#1 Posted : Thursday, March 3, 2011 1:14:40 PM(UTC)
ronco05
I have to replace the pump on my Kenmore HE2 washer model number 110.4752602. Do you have to get at the screws from underneath to replace the pump? I cant see how to remove it. Thanks
#2 Posted : Thursday, March 3, 2011 3:11:07 PM(UTC)
The instructions are attached to the reply.
- The drain pump Part number: AP4308966
File Attachment(s):
Duet sport - drain pump.doc (877kb) downloaded 232 time(s).
kevinballard1
#3 Posted : Saturday, July 16, 2011 7:58:04 AM(UTC)
kevinballard1
A big thank you to Gene for the downloadable step by step instructions on removing the HE2 drain pump. I am not the handiest guy, but I was able to take out the pump, remove a rubber band that had wrapped itself around the impeller blade, reinstall the pump, and get back to doing laundry.
#4 Posted : Monday, July 18, 2011 3:21:16 PM(UTC)
You are welcome. I'm glad it did help you and your washer is up and running.
