slg321
#1 Posted : Thursday, June 18, 2009 2:08:35 PM(UTC)
slg321
The freezer coils were icing up, so I replaced the defrost heater and thermostat. Defrost cycle now working fine, and the freezer temp went from stubbornly stuck on +22 degrees to -10. I turned the freezer temp control down and heard the damper close. Freezer went back to +20 and hasn't gone lower for 2 days, even with temp control back at max, even though the freezer coils are defrosting regularly.
Seems logical that the thermostat that controls the freezer damper might be bad, but I'm wary of the coincidence that the defrost heater, defrost thermostat, and fridge thermostat are all bad.
HELP... I must be missing something here. I'm not an appliance tech, but I'm a pretty good parts replacer. Having followed advice from other sources and tested/replaced the defrost system parts and still have the problem of a too warm freezer, does anyone have insght into what the problem is (before I end up dismantling this refirigerator peice by piece as I replace one part at a time)?
woodchuckie
#2 Posted : Thursday, June 18, 2009 2:29:23 PM(UTC)
woodchuckie
Did the damper ever open back up. Looking at your diagrams you may have a mechanical fridge temp adjustment. It just slides the damper open for the freezer air to cool the fridge.
Is the evaporator fan in the freezer running. It has to circulate the cold air.
Here's your diagrams> Replacement parts for WHIRLPOOL ET21DKXDW03 | AppliancePartsPros.com
slg321
#3 Posted : Thursday, June 18, 2009 3:17:29 PM(UTC)
slg321
Thanks for the quick reply!
Freezer evaporator fan is running. I assume the damper has not opened up; I didn't hear it move when I changed the freezer temp control back to max setting.
On the "Liner Parts" diagram, the left knob #22 controls the thermostat #13. In my fridge this is labelled as the fridge temp, while the right knob #22 is for freezer temp. So mine are either reversed from those shown in the diagram - or the damper controls how much cold air flows from rather than to the freezer. Does this sound right or am I not seeing something?
woodchuckie
#4 Posted : Thursday, June 18, 2009 8:27:05 PM(UTC)
woodchuckie
Yes, the damper controls how much cold air flows from rather than to the freezer. The fan in the freezer pulls the air across the evaporator and blows part of it through the damper opening.
slg321
#5 Posted : Friday, June 19, 2009 10:52:27 AM(UTC)
slg321
Then the damper seems to be stuck in the open position, letting too much of the cold air out of the freezer? What would make it stay open... bad damper or knob? Bad thermostat? What should I check next? Thanks for your help.
woodchuckie
#6 Posted : Saturday, June 20, 2009 4:23:36 AM(UTC)
woodchuckie
Diagram 3 shows your damper and damper linkage. It looks to be strictly mechanical. Broken or loose connectors possible. Part 9 maybe. Replacement parts for WHIRLPOOL ET21DKXDW03 | AppliancePartsPros.com
Guest (4)
Whirlpool Fridge GX5SHDXVA00 - Fridge Fine; Freezer Too Warm (Refrigerator & Freezer Repair)
by FamineLD 8/21/2023 4:54:57 AM(UTC)
GE ZISS42DCASS - Freezer too warm (Refrigerator & Freezer Repair)
by beb123 8/9/2022 12:55:43 PM(UTC)
Whirlpool Refridgerator GD5SHAXLQ02 - Freezer too warm (Refrigerator & Freezer Repair)
by Guest 3/1/2022 11:17:14 AM(UTC)
Frigidaire FRT17L3FW5 freezer too warm (Refrigerator & Freezer Repair)
by danielbraus 1/31/2022 10:38:31 AM(UTC)
Freezer too warm, fridge too cold (Refrigerator & Freezer Repair)
by Prepper 1/28/2018 10:10:48 AM(UTC)
Fridge and freezer too warm, fans and compresser run constantly (Refrigerator & Freezer Repair)
by klide 6/14/2016 7:18:50 AM(UTC)
Fridge and Freezer too warm (Refrigerator & Freezer Repair)
by collinsklein 12/28/2015 7:53:03 AM(UTC)
Fridge and freezer too warm in my side by side refrigeratorld enough (Refrigerator & Freezer Repair)
by Majdo 9/17/2015 11:52:33 AM(UTC)
by alan kundtz 5/9/2014 10:03:59 AM(UTC)
Kenmore fridge AND freezer too warm (Refrigerator & Freezer Repair)
by Xuor 2/27/2013 1:59:10 PM(UTC)
Fridge Okay, Freezer too warm, new Whirlpool (Refrigerator & Freezer Repair)
by Jody858 12/3/2012 10:48:24 AM(UTC)
freezer too warm to freeze solid (Refrigerator & Freezer Repair)
by ckat 11/22/2012 1:54:17 PM(UTC)
Fridge fine, Freezer too warm (Refrigerator & Freezer Repair)
by Dan Adler 7/12/2012 11:37:17 AM(UTC)
by rockislane 7/6/2012 6:12:24 AM(UTC)
Refrigerator and Freezer too warm (Refrigerator & Freezer Repair)
by Damian Marshall 3/11/2012 1:04:49 PM(UTC)
