Simon7012
#1 Posted : Wednesday, June 10, 2009 12:34:38 PM(UTC)
Simon7012
The cooktop is working while the control panel buttons are totally dead.
The clock is working with PF (power failure), is unable to adjust the time (off/cancel button is dead).
The oven is not working due to control panel buttons failure.
Please advise if the replacement of the control panel is needed.
Thank you.
Dan O.
#2 Posted : Thursday, June 11, 2009 2:00:27 PM(UTC)
Dan O.
Do you just mean PF is displaying rather then the clock actually 'working' and displaying the time? Or are both occurring together??
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Simon7012
#3 Posted : Thursday, June 11, 2009 5:18:29 PM(UTC)
Simon7012
Yes, it is showing PF and the clock is working and displaying the time.
The time is not correct and cannot be adjusted to the current time becasue all buttons (including the clear/adjust button to clear the "PF") on the control panel are dead.
Thank you.
Dan O.
#4 Posted : Friday, June 12, 2009 7:25:28 PM(UTC)
Dan O.
Simon7012 wrote:
all buttons on the control panel are dead.
That is most likely to be caused by a defective electronic control (see the following link) or somehow the ribbon connector running between the control panel keypad and the electronic control came loose for some reason. I think the latter is only a pretty slim possibility but certainly worth checking before replacing the control.
LINK > Whirlpool GY396LXPB00 Electronic Control
I think it highly unlikely a control panel would fail in such a way that absolutely all of its buttons were disabled at the same time. It might not be totally outside the realm of possibility though.
BTW. Have you tried disconnecting power from the appliance for a minute or two to see if maybe the control would reset?
Dan O.
=D~~~~~~
Simon7012
#5 Posted : Friday, June 12, 2009 9:03:52 PM(UTC)
Simon7012
Yes, I have tried to turn off the power for few minutes and then turn on again. All buttons on the control panel were not working.
Even I tried the second time waiting for more than 2 hours before turning on the power again, the buttons were dead except the clock with PF.
May be I need to replace the whole control panel.
Thank you so much for your advice.
Dan O.
#6 Posted : Saturday, June 13, 2009 8:17:07 AM(UTC)
Dan O.
Quote:
Maybe I need to replace the whole control panel.
There is a control "panel" (item # 1 at the following link) which has the keypad where you press buttons for settings and time, etc. Basically a decorative panel. There is also the electronic control (item # 3 in the illustration) behind the control panel which is what actually does all the work of controlling the appliance's functions.
LINK > GY396LXPB00 Control Panel Exploded Parts View Illustration
I suggested the electronic control (not the control "panel") might be the most likely culprit but the control panel might be a possibility as well as stated above. Each of those are individual components and not sold together as a single assembly.
JFYI
Dan O.
=D~~~~~~
Jenn Air Slide In Range Control Panel / Display (Oven Repair (including Ranges and Cooktops))
by blueovalsvt 10/27/2017 8:01:07 AM(UTC)
GE Cafe Range Control Panel not responding (Oven Repair (including Ranges and Cooktops))
by Bob21228 8/7/2017 8:08:58 PM(UTC)
Electric Jenn-Air Range Control Panel (Oven Repair (including Ranges and Cooktops))
by LAWood 7/7/2013 10:02:42 AM(UTC)
Kitchen Aid Range control panel (Oven Repair (including Ranges and Cooktops))
by boblinfortino 2/12/2013 8:05:45 AM(UTC)
GE Cooking Range control panel info (Oven Repair (including Ranges and Cooktops))
by repairgal 9/13/2012 6:29:33 PM(UTC)
Amana Range control panel (Oven Repair (including Ranges and Cooktops))
by EricSirls 9/7/2012 12:51:37 PM(UTC)
Frigidaire gas range control panel--price? (Oven Repair (including Ranges and Cooktops))
by bpjdoc 8/3/2012 6:18:25 AM(UTC)
Range control panel out stove top working (Oven Repair (including Ranges and Cooktops))
by nonlocal 1/3/2012 4:20:41 AM(UTC)
Frigidaire Range Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by Bruce7799 12/15/2011 5:11:43 PM(UTC)
Amana Gas Range Control Panel Display (Oven Repair (including Ranges and Cooktops))
by jose2741 6/17/2011 4:36:32 AM(UTC)
Magic Chef Range Control Panel Problem (Oven Repair (including Ranges and Cooktops))
by gnit2000 1/9/2011 1:30:17 PM(UTC)
whirlpool range control panel cutting off (Oven Repair (including Ranges and Cooktops))
by preissheights 12/28/2010 5:22:24 AM(UTC)
Maytag range control panel quit working (Oven Repair (including Ranges and Cooktops))
by herrtony 2/2/2010 8:59:35 AM(UTC)
Question about Kenmore Gas Range Control Panel (Oven Repair (including Ranges and Cooktops))
by Xelveki 1/4/2010 9:31:21 PM(UTC)
Frigidaire range control panel gone blank (Oven Repair (including Ranges and Cooktops))
by carlcad 12/28/2009 9:18:28 AM(UTC)
