The control panel read out goes on and off intermittently. Everything still works but you can not see oven temperature or clock,timer etc. Wondering if it is the panel itself or the computer module? They are both expensive and I don't want to quess. Is there some kind of replaceable thermal fuse that can be the problem?
Thanks much
Bob
Groups: APP Team
Hi, Bob. I really don't think that that the thermal fuse will fix this problem. You need to replace the main control board Part number: 9782455
I am having a problem too
My stove the top works normally but the oven display is blank,is the module bad?
