Tedwards
#1 Posted : Thursday, May 28, 2009 10:28:33 AM(UTC)
Tedwards
Hello
I have a GE TFH24PRSBAA Refrig.
Freezer is freezing up, Refrig gets warm.
How do I determine if the problem is the defroster thermostat or the defroster heater?
Thanks in advance for your responses.
woodchuckie
#2 Posted : Thursday, May 28, 2009 11:58:00 AM(UTC)
woodchuckie
Turn the defrost timer till everything cuts off. If the heater comes on the problem is your timer. If it doesn't come on, check if for continuity with an ohm meter or inspect it for burns. The defrost thermostat should read closed when cold and open when warmer with an ohm meter. Your timer is part 257 on diagram 4. Replacement parts for GE TFH24PRSBAA | AppliancePartsPros.com
Tedwards
#3 Posted : Thursday, May 28, 2009 12:06:46 PM(UTC)
Tedwards
Thanks for pointing out the timer, I didn't know if this model had one.
I'll check this out.
Thanks again
whirlpool side by side freezing up periodically (Refrigerator & Freezer Repair)
by Guest 11/2/2023 6:19:56 AM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
newer ge french door ref water line freezing up (Refrigerator & Freezer Repair)
by Brysonsdad 11/23/2022 5:31:53 AM(UTC)
Evaporator Coil Freezing Up (Refrigerator & Freezer Repair)
by Guest 6/24/2022 7:18:58 PM(UTC)
fridge freezing up anf not cold (Refrigerator & Freezer Repair)
by mobetter 7/6/2021 8:51:05 PM(UTC)
Refrigerator side freezing up on top of unit inside GE PSB42LSRBBV (Refrigerator & Freezer Repair)
by peeky 4/26/2021 6:26:20 AM(UTC)
GE Refrigerator PFSF6PKXDWW evaporator drain hole still freezing up. (Refrigerator & Freezer Repair)
by RobGrrr 4/20/2021 8:28:02 AM(UTC)
GE Refrigerator Freezing Up After Replacing Main Board (Refrigerator & Freezer Repair)
by malochala 8/2/2019 1:22:43 PM(UTC)
Kenmore elite keeps freezing up evaporater fan not running (Refrigerator & Freezer Repair)
by Joe craft 1/28/2019 11:06:51 AM(UTC)
Ice Maker Freezing up (Refrigerator & Freezer Repair)
by Margni 4/4/2018 3:10:49 PM(UTC)
SxS - lower vent freezing up (Refrigerator & Freezer Repair)
by wwodzien 3/26/2018 7:22:52 PM(UTC)
Evaporator freezing up (Refrigerator & Freezer Repair)
by tbanks204 3/26/2018 2:22:14 PM(UTC)
French Door Ice Maker line freezing up (Refrigerator & Freezer Repair)
by JoeGolan 4/13/2017 5:14:46 AM(UTC)
Amana Freezer Freezing Up (Refrigerator & Freezer Repair)
by Shinnymoon 2/25/2017 10:50:31 AM(UTC)
Side by side coils freezing up (Refrigerator & Freezer Repair)
by delifolk1964 6/30/2016 10:07:19 AM(UTC)
