This unit is freezing up: Replaced Defrost heater element Replaced Defrost Thermostat Unit is still Freezing up, it appears to run longer that normal, compressor will shut off if cold control turned down enough. otherwise this unit cools great and freezer works great. Any Suggestions, thoughts, Ideas on what to replace next assuming the new parts are working correctly? Thank You
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
No I have not, as it would be the most expensive repair.
I would not be opposed to doing so, but I can't be sure this was the culprit, or the temperature control thermostat, I guess I could replace both, the temp control is not overly expensive.
Groups: Expert
The temp. control is NOT part of the defrost system.
Groups: Expert
Take this no. and do a search on amazon. 4388932
