Middleton
#1 Posted : Tuesday, May 26, 2009 11:16:38 AM(UTC)
Middleton
I have a Maytag washer where the agitator will not stay down. During a wash cycle the agitator pops up and then does not agitate. What part do I need to repair this?
applianceman
#2 Posted : Tuesday, May 26, 2009 4:29:59 PM(UTC)
applianceman
First make sure the setscrew in the bottom of the agitator has not come loose. But the clip that holds the shaft in the transmission is most likely broken #16 on your transmission parts breakdown. It’s just a white plastic half moon clip. You will have to have a tool to take the spin basket out without damaging it. This page will explain how to do this since you are not replacing the tub seal you will not have to follow all the steps. Just go until you can see the clip. Maytag Tub Seal Replacement
One thing I will warn is that when the transmission shaft lifts up as you describe water may have entered the transmission. If you suspect this may have happen you will need to drain the transmission and fill it with new oil. The part number for the oil is 056080.
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
washer agitator shaft. (Washer Repair)
by roots398 1/19/2021 8:27:49 AM(UTC)
Maytag Centennial Top Loading Washer Agitator Issue (Washer Repair)
by BluEclipse17 2/15/2020 7:56:31 AM(UTC)
Maytag Washer agitator slipping (Washer Repair)
by Waywardson 4/4/2019 7:45:47 AM(UTC)
Whirlpool Washer Agitator Noise / No Spin (Washer Repair)
by BobTh 3/1/2017 11:06:09 AM(UTC)
Washer agitator on statr and not spinning dry (Washer Repair)
by redneckbuckeye 7/14/2016 1:30:43 PM(UTC)
Washer agitator is loose (Washer Repair)
by civwiz5 4/26/2015 12:14:47 PM(UTC)
Kenmore Stacked W/D - Washer Agitator grinds, skips, stops. (Washer Repair)
by jchesna 11/16/2014 7:43:44 PM(UTC)
Removal of GE Hydrowave washer agitator (Washer Repair)
by Dave Storck 3/30/2014 11:18:01 AM(UTC)
Washer agitator dogs - strange (Washer Repair)
by cmcd 12/3/2013 2:08:56 PM(UTC)
GE Washer Agitator Noise (Washer Repair)
by brettdog 11/18/2013 11:13:48 AM(UTC)
GE washer agitator keeps running! (Washer Repair)
by bkbucs 10/10/2013 5:57:36 PM(UTC)
G.E. Washer agitator not spinning (Washer Repair)
by familymechanic 8/10/2013 7:42:35 AM(UTC)
Whirlpool washer agitator starts as soon as washer is turned on. (Washer Repair)
by Ferenceh 5/4/2013 12:36:30 PM(UTC)
Washer Agitator makes loud noise in Heavy Duty Mode (Washer Repair)
by lvallanc 1/26/2013 7:08:48 AM(UTC)
