von.ahouse@hotmail.com
#1 Posted : Sunday, October 29, 2017 8:46:57 AM(UTC)
Stumped! I inadvertently hit the "clean" button (didn't have my glasses on). When I realized what I had done, I started pushing buttons to turn the feature off. Anyway, I opened the door before it had a chance to lock, and the lock engaged. I now have a door that won't close because the lock is engaged, and I can't get it to un-engage. I tried a reset (turning it off at the panel for a minute or so)(no luck). Someone mentioned leaving it off for "a couple of hours", so that's where I am now. Been turned off for about an hour now. I found this forum, so I thought I'd "seek professional help" :) Any quick fixes? Thanks!
ThatGuy
#2 Posted : Sunday, October 29, 2017 10:37:42 AM(UTC)
ThatGuy
Groups: Expert
United States
There should be a door switch on the oven near the top, left of the opening. If you depress the switch with your finger, you should be able to cancel the oven cleaning cycle and the door lock should unlock. You might have to run it again to get it to unlock.
I hope you didn't bend the door lock arm.
#3 Posted : Sunday, October 29, 2017 10:56:54 AM(UTC)
Thanks. Tried that. Right now, the screen is showing “LOC”, and the “door locked” is illuminated below the time. Owners manual says that I have to wait (an hour or so) for the oven to cool and the lock to disengage. I have the door closed on a small block of wood that’s keeping that button you mentioned pushed in. Hoping this works. This actually happened last night, so I’ve been looking for solutions all day. I guess I’ll call “tech support “ tomorrow if I can’t rectify it sooner.
Guest (4)
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
Oven Door Locks on its own (Oven Repair (including Ranges and Cooktops))
by TheTryckster 5/20/2015 11:02:43 AM(UTC)
ge double oven door locked (Oven Repair (including Ranges and Cooktops))
by jswim788 1/31/2015 11:30:12 AM(UTC)
Oven door locked, no power? (Oven Repair (including Ranges and Cooktops))
by reckless67 10/27/2013 1:50:44 PM(UTC)
Self-cleaning oven door locks and unlocks - repost (Oven Repair (including Ranges and Cooktops))
by dgray7114 9/12/2012 11:47:04 AM(UTC)
Thermador Dual fuel range oven door locked and f3 code. (Oven Repair (including Ranges and Cooktops))
by mikey77 7/28/2012 7:14:51 AM(UTC)
by Catherine E 2/2/2012 6:18:56 PM(UTC)
oven door locked after using auto clean??? (Oven Repair (including Ranges and Cooktops))
by sheldon friedland 12/8/2011 6:53:53 AM(UTC)
Whirlpool accubake oven door locking problem (Oven Repair (including Ranges and Cooktops))
by ZDM 10/16/2011 8:53:11 AM(UTC)
GE Profile Oven Door lock stuck on... (Oven Repair (including Ranges and Cooktops))
by johndw 5/27/2011 6:29:32 PM(UTC)
Replaced ERC, now oven door locks continually (Oven Repair (including Ranges and Cooktops))
by tlynchard 4/14/2011 2:54:12 PM(UTC)
Upper Oven Door Locked, No Display, Self-Cleaning (Oven Repair (including Ranges and Cooktops))
by thomasjrozzi 1/9/2011 11:14:15 AM(UTC)
oven door locked self cleaning wont stop (Oven Repair (including Ranges and Cooktops))
by karenmsk 11/5/2010 6:19:42 AM(UTC)
