davestlc
#1 Posted : Sunday, September 17, 2017 6:49:27 AM(UTC)
davestlc
Where is the balance ring located on this HE top loading model? Thanks.
PNWDrew
#2 Posted : Sunday, September 17, 2017 12:38:14 PM(UTC)
PNWDrew
It's part of the spin basket, under the tub ring. If you lift the whole deck the tub ring unclips from the tub and exposes the top of the basket, that plastic top edge is it. Not a separate part #.
Why do you want to replace balance ring?
Samsung washer, bad balance ring? (Washer Repair)
by Branmuffin 7/12/2017 7:46:57 PM(UTC)
Outer tub bearings & Balance Ring (Washer Repair)
by subsailor 6/23/2014 3:25:12 PM(UTC)
Balance ring 3956205 tight fit (Washer Repair)
by Oldman1 4/3/2013 11:28:44 AM(UTC)
replacing the balance ring (Washer Repair)
by gbonin 1/5/2013 4:12:55 PM(UTC)
by judyjoe4250 3/19/2011 1:59:15 PM(UTC)
washer repair balance ring (Washer Repair)
by offshore1 3/13/2010 8:34:08 AM(UTC)
Balance Ring hitting Ring Tub and water on floor (Washer Repair)
by mrwto 1/26/2010 1:34:37 PM(UTC)
Top Tub and balance ring (Washer Repair)
by Patrah1 11/1/2009 2:10:58 PM(UTC)
Balance ring (Washer Repair)
by MikeZ 1/29/2009 8:02:21 AM(UTC)
