judyjoe4250
#1 Posted : Saturday, March 19, 2011 1:59:15 PM(UTC)
judyjoe4250
I Just Replaced A Water Pump And Belt For The Maytag Washer Listed Above. I Removed The Inner Tub To Clean Out Dirt And Scum Build Up And Noticed That There Is Water Sloshing Inside The Balance Ring. Is This Normal, And How Do I Remove It?
sidfink43
#2 Posted : Monday, March 21, 2011 5:02:06 PM(UTC)
sidfink43
This is normal, it is used to dampen some of the vibration of the machine.
balance ring (Washer Repair)
by davestlc 9/17/2017 6:49:27 AM(UTC)
Samsung washer, bad balance ring? (Washer Repair)
by Branmuffin 7/12/2017 7:46:57 PM(UTC)
Outer tub bearings & Balance Ring (Washer Repair)
by subsailor 6/23/2014 3:25:12 PM(UTC)
Balance ring 3956205 tight fit (Washer Repair)
by Oldman1 4/3/2013 11:28:44 AM(UTC)
replacing the balance ring (Washer Repair)
by gbonin 1/5/2013 4:12:55 PM(UTC)
washer repair balance ring (Washer Repair)
by offshore1 3/13/2010 8:34:08 AM(UTC)
Balance Ring hitting Ring Tub and water on floor (Washer Repair)
by mrwto 1/26/2010 1:34:37 PM(UTC)
Top Tub and balance ring (Washer Repair)
by Patrah1 11/1/2009 2:10:58 PM(UTC)
Balance ring (Washer Repair)
by MikeZ 1/29/2009 8:02:21 AM(UTC)
