Started load to wash blanket. Leaking water everywhere. Turned it off but water kept running into tub. pulled selector knob out and water just kept coming. help
If it fills while the power is off your water valve is stuck open. Test it by opening the house valve with the machine unplugged. If it immediately begins to fill that is your washer's fill valve. If it's leaking only when it runs we'll need to look farther.
