Suddenly after the water dispenser stuck "on" and I opened the door to stop the flow, the water has deiced not to dispense at all. I have replaced the water intake valve, the water filter, and done the"thaw out" repair. Ice maker is working fine. Water is coming out of the hose (with good pressure) at the bottom of the freeze door when I disconnect there and activate the lever. When lever is activated it engages, and it makes noise like it wants to dispense, but nothing comes out... any ideas? would it make sense to replace the dispenser module now that I have basically tried everything else I can think of? Thanks for your input.
