writesds
#1 Posted : Wednesday, October 31, 2012 5:37:40 AM(UTC)
writesds
Water supplied to icemaker but not water coming from tap. Where is the hang-up? Thanks
Simon / APP Team
#2 Posted : Wednesday, October 31, 2012 11:05:36 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you don't hear a click and light doesn't come on when you press the water lever then most likely there is a problem with the switch or the switch bracket Part number: 2180226
If the light comes on then most likely it's frozen or broken water line or broken water inlet valve.
Pull off the toe grill, locate the water line connection and disconnect one side.
With the doors closed press the water lever. If the water comes out the tube - that means that the water line inside the freezer door is frozen.
Defrost the freezer for 24 hrs.
If not - trace the line back to the chiller inside the refrigerator and then to the water valve.
Here are the breakdown diagrams and Dispenser Front parts for Whirlpool GD25DFXFN01 - AppliancePartsPros.com
Post the results.
Simon.
GE Refrigerator not cooling properly/ water not dispensing (Refrigerator & Freezer Repair)
by tatkins85 3/18/2021 6:48:15 AM(UTC)
Please Help,GE Fridge Water not dispensing and other issues. # PSS25MGMAWW (Refrigerator & Freezer Repair)
by c.marvin077 2/11/2017 8:02:28 AM(UTC)
Bosch b20cs50sns /02 water not dispensing (Refrigerator & Freezer Repair)
by Dcoop14 9/14/2015 3:57:25 PM(UTC)
frigidaire water not dispensing (Refrigerator & Freezer Repair)
by aepmartin 9/30/2013 7:17:59 PM(UTC)
Ice and Water not dispensing (Refrigerator & Freezer Repair)
by Napi333 7/26/2013 4:07:12 PM(UTC)
Whirlpool ice and water not dispensing (Refrigerator & Freezer Repair)
by tr8d31 3/19/2013 8:41:30 AM(UTC)
Water not dispensing, but makes & dispenses ice. (Refrigerator & Freezer Repair)
by IARidgeRunner 11/29/2012 7:57:52 PM(UTC)
GE Side by Side, ice water not dispensing (Refrigerator & Freezer Repair)
by brianmccarthy24 7/9/2012 1:12:38 PM(UTC)
Water not dispensing in a side by side refrigerator (Refrigerator & Freezer Repair)
by corvettet 12/2/2011 7:21:56 AM(UTC)
Water NOT dispensing but Icemaker working (Refrigerator & Freezer Repair)
by KeithGP 11/4/2009 11:45:12 AM(UTC)
water not dispensing from door (Refrigerator & Freezer Repair)
by toreitha 3/9/2009 7:57:58 AM(UTC)
Freezer not working/Water not dispensing (Refrigerator & Freezer Repair)
by bodina 1/28/2009 6:36:57 AM(UTC)
GE Hot Point Refrig. water not dispensing?? Help.. (Refrigerator & Freezer Repair)
by rfrye8657 1/4/2009 2:47:58 PM(UTC)
GE Side-by-side water not dispensing (Refrigerator & Freezer Repair)
by jhonny 2/14/2008 12:28:36 PM(UTC)
Ice maker working, but water not dispensing (Refrigerator & Freezer Repair)
by ccssball1 1/27/2008 6:09:47 AM(UTC)
