My side by side refrigerator dispenser is not functioning properly. There is water coming from the main line into the line that leads to the filter canister. Once the water reaches the canister it overflows the canister like it is not being suctioned out. The same happens if I turn the ice dispenser on. I can hear the ice dispenser pulling water then once it reaches the filter it overflows never making it to the ice maker. I replaced the filter so it is not that. I checked all the hoses per the manual and they are working as intended.
Originally Posted by: aepmartin  My side by side refrigerator dispenser is not functioning properly. There is water coming from the main line into the line that leads to the filter canister. Once the water reaches the canister it overflows the canister like it is not being suctioned out. The same happens if I turn the ice dispenser on. I can hear the ice dispenser pulling water then once it reaches the filter it overflows never making it to the ice maker. I replaced the filter so it is not that. I checked all the hoses per the manual and they are working as intended. Frigidaire FRS26R4AW6
