2 Pages12>
projvw18t
#1 Posted : Thursday, November 3, 2016 9:38:11 AM(UTC)
projvw18t
3 1/2 years old fridge...
Here is my issue:
Bottom freezer is not cooling enough to keep things frozen.
-Compressor running constantly and very hot (burns skin)
- Fan is spinning fast and constantly
- I cleaned condenser coils
- I tried to unplug it and leave the compressor cool down with a domestic fan on it for 30 minutes, plugged it back and it was running hot 5 minutes later.
Any help would be very appreciated!
Thank you!
projvw18t
#2 Posted : Thursday, November 17, 2016 4:53:55 AM(UTC)
projvw18t
Anyone can help?? It has been working fine for the last 10 days but now the content of the freezer is slowly unfreezing and the compressor is running constantly...
Thank you
cbmserviceguy
#3 Posted : Monday, November 21, 2016 10:42:25 AM(UTC)
cbmserviceguy
Look inside the freezer at the back wall. See if there is any frost visible back there. Sounds like a defrost issue or a sealed system leak/restriction.
projvw18t
#4 Posted : Tuesday, November 22, 2016 5:07:31 AM(UTC)
projvw18t
Thanks for your help.
There was a little piece of ice on the back wall. I'll post a picture of it.
projvw18t attached the following image(s):
cbmserviceguy
#5 Posted : Tuesday, November 22, 2016 5:19:54 AM(UTC)
cbmserviceguy
I'm not sure how technical you are, but you are going to need to pull that back panel and have a look at the frost pattern on the evaporator. I suspect you are low on freon and the frost pattern will be very weak. It's a little bit of a chore to get into that section. The link below is a good video for getting it apart.
https://www.youtube.com/watch?v=VVBkMsXsn_4
Take some pics of what you find back there and post them here please.
projvw18t
#6 Posted : Tuesday, November 22, 2016 10:58:15 AM(UTC)
projvw18t
Thank you I will do it as soon as I can and post what I can see
projvw18t
#7 Posted : Tuesday, November 22, 2016 7:17:45 PM(UTC)
projvw18t
If it can help with the diagnosis, a whirlpool technician changed the drain tube for a new redesigned drain tube kit a year ago. The freezer was creating a lot of ice in the bottom of the freezer. Since then, the bottom stays perfectly clear of any ice.
projvw18t
#8 Posted : Saturday, November 26, 2016 7:21:26 AM(UTC)
projvw18t
projvw18t
#9 Posted : Saturday, November 26, 2016 7:28:52 AM(UTC)
projvw18t
So here is what I saw with the panel removed. I let the ice completely melt down through the drain tube into th drain pan. I used a vaccuum to empty the drain pan. Once everything was dry, I put the panel and hardware back in place and plugged the fridge. I will wait 24 hours tu see if it runs better or not.
Any idea what could be the cause or what to replace?
Thanks again
projvw18t
#10 Posted : Saturday, November 26, 2016 10:16:21 AM(UTC)
projvw18t
After some reading on different forums, the frost pattern indicates a major problem...
Your help would be very appreciated
Guest (6)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by edmiller 9/1/2016 8:32:25 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
Frig and freezer not cold enough (Refrigerator & Freezer Repair)
by themayhews 9/24/2015 9:57:47 AM(UTC)
by billpulsipher@gmail.com 8/28/2015 11:25:19 AM(UTC)
Kenmore fridge cold freezer not cold enough (Refrigerator & Freezer Repair)
by Jasonywu 8/6/2015 2:05:17 PM(UTC)
by Suzalasue 5/28/2015 6:08:45 AM(UTC)
by wnorton 1/27/2015 3:21:20 PM(UTC)
Freezer not cold enough, fridge working (Refrigerator & Freezer Repair)
by JDM1oc 12/4/2014 8:36:25 PM(UTC)
2 Pages12>
