Whirlpool Dryer Model WED4800XQ0 Was heating occasionally. After replacing parts, now does not heat at all. Got all parts from you. Here is what I have replaced: AP3094244: Dryer thermal cut-off kit AP6008373: Cycle Switch AP6008325: Dryer Thermal Fuse AP3094254: Dryer heating element
Suggestions now?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
One of two problems may be causing the issue from the start. 1. The timers heating contact may be bad, not making contact or the points may be burnt, which sends power from lead 1 to the heating element via the thermostats. 2. The motors centrifugal switch might have burnt points not send power from Lead 2 to the heating element.
What are your part numbers for these?
