jpdkrty
#1 Posted : Saturday, August 13, 2016 3:50:00 PM(UTC)
jpdkrty
I have checked continuity on all heater components - thermal fuse, heating element, high limit thermostat, dryer door switch, cycling thermostat. All test OK with ohmmeter. When I removed the temp selector switch (low/medium/high) it appears to be switching OK. With the switch out of the circuit, the element is powered and hot air is produced (very hot), when I plugged switch in again - no power to element, but other functions work - timer switch, blower motor, etc. Is this selector switch defective or is it something else in the circuit? Logically, I must be missing something.
brobriffin
#2 Posted : Wednesday, August 17, 2016 7:27:32 AM(UTC)
brobriffin
Man
United States
Possibly this switch is bad. Here is the part you need. Whirlpool WP3399639 Switch, Cycle - AppliancePartsPros.com
Remember our Buy n Try policy, if this doesn't remedy your problem you can return the part.
jpdkrty
#3 Posted : Monday, August 22, 2016 5:46:46 AM(UTC)
jpdkrty
Thank you for your reply. I checked the continuity of the selector switch and found it to be good. The next item down the line was the timer switch. I replaced the TIMER WPW10186032. While a rare fail, replacing this Timer appears to have solved the riddle. No way to easily check operation of the TIMER, but dryer now heats up on each selector switch setting. I took the opportunity to replace vent connection and clean dryer vent line thoroughly. Runs much better.
Kenmore dryer not heating properly (Dryer Repair)
by yyzt4e 7/8/2015 4:58:45 PM(UTC)
Kenmore Dryer Not Heating After We Did Changed the Rear Drum Felt Seal (Dryer Repair)
by kytre 6/2/2015 7:25:49 PM(UTC)
Kenmore Dryer not heating (Dryer Repair)
by bkenner 3/23/2014 5:42:55 PM(UTC)
Kenmore dryer not heating (Dryer Repair)
by Drichie 5/21/2013 3:29:30 PM(UTC)
Kenmore dryer not heating - next steps? (Dryer Repair)
by bangelus 12/6/2012 5:59:36 AM(UTC)
by murphy7513 7/4/2012 8:17:34 PM(UTC)
by PIO_ACA_CMY 1/5/2012 3:23:10 PM(UTC)
kenmore dryer not heating (Dryer Repair)
by bwoltanski 12/27/2011 9:01:29 AM(UTC)
by Dando 6/18/2011 12:45:41 PM(UTC)
by TexFordD 3/20/2011 10:15:14 AM(UTC)
by JaxMax 3/14/2011 9:11:16 AM(UTC)
by MBKENMORE 9/8/2010 10:00:42 AM(UTC)
by RepDry 9/23/2009 4:48:25 PM(UTC)
by lego1231 9/21/2009 8:18:43 AM(UTC)
Electric Kenmore Dryer not heating (Dryer Repair)
by morenojx 9/2/2009 7:32:58 AM(UTC)
