Iceman675
#1 Posted : Sunday, April 24, 2016 7:40:31 AM(UTC)
Iceman675
I have an older Kenmore washer model 11092586410, that will fill and agitate, but will not, sometimes, drain and spin.
More often "will not" lately.
Only one motor, connected directly to the transmission, with a coupling that is good. No belts.
Water pump is connected directly to the back of the motor.
The way this works " I think " is that the motor runs in one direction for agitate and the other for spin and drain.
Is this assumption correct ?
So, I am thinking either the motor control board or the timer is defective.
http://www.********************...586410/0582/0153200.html
Appliance Medics
#2 Posted : Sunday, April 24, 2016 9:55:14 AM(UTC)
Appliance Medics
On this model if you can hold the lid switch down and put the unit into spin you want to check when it doesn't if it's a heavier load it could have a bad brake and clutch, or a bad spin tube assembly, or a bad transmission. All of which can cause the same issue.
Iceman675
#3 Posted : Sunday, April 24, 2016 3:33:24 PM(UTC)
Iceman675
As I see it, as the water pump has no solenoid to control water flow, so the motor must be ran in the opposite direction from the agitate mode for the spin mode and water pump to operate. If the motor runs in spin mode the water pump would drain the tub, unless the motor locks up via the transmission when in spin mode. If that happens the water pump won't operate and the tub would not drain, which it doesn't. As the water pump is directly attached to the rear of the motor.
Would any of the above replied items cause the motor to freeze, or lock up while in the spin mode ? "bad brake and clutch, or a bad spin tube assembly, or a bad transmission"
With the motor removed, I can turn the the motor coupling to the transmission and the tub turns fast as if in the spin cycle.
thanks
Appliance Medics
#4 Posted : Monday, April 25, 2016 8:09:55 AM(UTC)
Appliance Medics
Check your lid switch. It will not spin if the machine thinks the lid is up. Let me know what you find
Iceman675
#5 Posted : Friday, April 29, 2016 2:48:56 PM(UTC)
Iceman675
Pulled the lid switch, checked it with an ohm meter, on the bench and again in the machine opening and closing the lid. Switch was an open circuit with the lid up and a closed circuit with lid closed.
I'll try a test load in a few days before doing anything else.
Appliance Medics
#6 Posted : Tuesday, May 10, 2016 12:37:20 PM(UTC)
Appliance Medics
Just got back from vacation. Still having trouble?
Guest (5)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg 5/18/2024 6:29:18 AM(UTC)
Older Kenmore Washer leak (Washer Repair)
by Guest 2/1/2024 9:56:27 AM(UTC)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 6/1/2023 12:44:27 PM(UTC)
Kenmore washer error codes (Washer Repair)
by Guest 3/5/2023 7:00:21 AM(UTC)
Kenmore Washer spin problem (Washer Repair)
by vlherring 1/17/2023 8:10:33 AM(UTC)
Kenmore washer overflowing (Washer Repair)
by wgreene 12/21/2022 4:51:59 AM(UTC)
Kenmore washer 110 271132410 (Washer Repair)
by chris1025 12/20/2022 8:46:26 AM(UTC)
Kenmore Washer will not agitate, but it will spin (Washer Repair)
by mjaymadson 8/2/2022 9:37:22 PM(UTC)
Kenmore washer/dryer stackable combo stops (Washer Repair)
by philio22 5/1/2022 5:30:10 PM(UTC)
Kenmore Washer 110.21302013 leaving lint and hair all over clothes after several washes (Washer Repair)
by aspitale 2/12/2022 9:17:17 PM(UTC)
Kenmore washer agitation trouble (Washer Repair)
by mingmen 1/9/2022 6:01:44 PM(UTC)
Kenmore washer tub (Washer Repair)
by Guest 1/9/2022 11:21:02 AM(UTC)
Kenmore washer 796.40272900 shuts off after running about 5 minutes (Washer Repair)
by Guest 12/12/2021 2:17:32 PM(UTC)
Kenmore Washer fails to stop intermittently (Washer Repair)
by fuhrmanrl 9/22/2021 5:13:46 PM(UTC)
