Washer does NOT power-up. No lights, etc. YES have verified electrical outlet working (test light & separate desk lamp used to test)
What are likely cause ??
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Model #GTW720B5N0WS Water drips into the machine when it’s shut off and eventually starts a cycle. Shutting off the hot water stops this. Know a solution?
