Joined: 5/1/2022(UTC) Posts: 0  Location: Pennsylvania
I have a Kenmore washer/dryer stackable combo model 363.61542411. Washer will fill partially with water. It will shut off as if receiving no power. After one to fifteen minutes, it will start up again and complete the remaining load as normal. I've replaced the pressure switch and water inlet valve. Any suggestions? Thank you in advance.
