chuckb218
#1 Posted : Friday, January 29, 2016 2:14:04 PM(UTC)
chuckb218
So I replaced the water inlet valve because the old one had no continuity. It worked! Yay! Once...... now the new valve which passes the continuity check just hums. I manually changed the float and that seems turn off and on the now humming water inlet valve. Any ideas what could be wrong? Did the new valve fail after one use?
#2 Posted : Saturday, January 30, 2016 2:58:15 AM(UTC)
Parts for Whirlpool DU850SWPQ4 Dishwasher - AppliancePartsPros.com
See the attachment for the wiring diagram.
Check the voltage across the water valve when it is on.
If it is 120 volts then there is a problem with the valve.
Could be that when you replaced the valve that some scale got loose from the pipes and is now plugging the valve or at least causing problems.
Remove the valve and check/clean the screen filter on the input side.
Do not remove it as it is there to keep crud out of the valve which could cause a flood.
If the filter is clean then my guess is that the valve is defective.
chuckb218
#3 Posted : Saturday, January 30, 2016 5:33:09 AM(UTC)
chuckb218
BrassCraft, 3/8 in. Compression x 3/8 in. Compression x 48 in. Braided Polymer Dishwasher Connector with 3/4 in. Garden Hose Elbow, B1-48DW12 P at The Home Depot - MobileChecked the screen, blew it out with compressed air. Then took the hose off and tried blowing through it and it was plugged. Cleaned it out and it's now working perfectly. Thanks for the help and input! Sorry I didn't know how to shorten that link.
#4 Posted : Saturday, January 30, 2016 7:15:45 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Amana washer not filling properly (Washer Repair)
by carcajou 5/12/2023 10:53:05 AM(UTC)
GE PFE28RSHSS Door Ice Maker not filling (Refrigerator & Freezer Repair)
by msrkseger 3/15/2023 6:52:44 AM(UTC)
Ice Maker not filling with water. Water dispenser works. Kenmore Elite (Refrigerator & Freezer Repair)
by jeffrich12 1/21/2023 9:13:34 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
KitchenAid KUDS30IXBLA Dishwasher Not Filling Up With Enough Water (Dishwasher Repair)
by navagator 2/6/2021 3:49:58 PM(UTC)
GE Profile not filling all the way (Dishwasher Repair)
by BeardedSerb 1/29/2021 6:00:24 AM(UTC)
dishwasher not filling mdb5600awb (Dishwasher Repair)
by sac65849 1/4/2021 8:56:23 PM(UTC)
Bosch SHE43RL6UC/64 Not filling (Dishwasher Repair)
by ScottFerguson 8/2/2020 11:08:08 AM(UTC)
Speed Queen washer not filling (Washer Repair)
by CraigRich 4/7/2020 1:39:07 PM(UTC)
KitchenAid KUDR01TJBT0 DISWASHER not filling (Dishwasher Repair)
by TFGTech 1/21/2020 3:17:30 PM(UTC)
ICEMAKER not filling; Water dispenser works (Refrigerator & Freezer Repair)
by WhirlyPair 1/29/2018 4:57:03 PM(UTC)
Frigidaire, not filling fully, and not washing (Dishwasher Repair)
by haze 3/27/2017 2:21:19 PM(UTC)
whirlpool washer agitating, but not filling on startup. (Washer Repair)
by richfix 3/13/2017 11:34:47 AM(UTC)
GE Dishwasher not filling with water (Dishwasher Repair)
by shawnkocher508 10/31/2016 12:12:32 PM(UTC)
