I am troubleshooting a dishwasher that will not fill I removed the water inlet valve and it looks fine (filter not plugged) When I tested the power connections with a volt meter I believe I am supposed to see 120 VAC when the dishwasher fills. I see 37 volts when I first start the cycle, but then it drops to 1 VAC when it is supposed to fill. How do I troubleshoot from here? The KitchenAid model I have has an electronic control panel. Does this mean the control panel is shot, or is there an easier fix? Thanks
