natalieandreasen@yahoo.co
#1 Posted : Tuesday, May 19, 2009 8:06:24 PM(UTC)
Our Dryer is not producing any heat. We replaced the heating element and still no heat. Now how do I know if I need to replace the fuse, or the thermostat? What do you suggestwe do next? Thank You, Natalie Andreasen
libertyappl
#2 Posted : Tuesday, May 19, 2009 8:09:19 PM(UTC)
libertyappl
Natalie,
Most likely the thermostat is your problem, the if the thermal fuse were out the unit wouldn't turn on. This is the part you need, Replacement parts for WHIRLPOOL LER7646JQ0 | AppliancePartsPros.com
Nat (Natalie) LOL
#3 Posted : Wednesday, May 20, 2009 2:45:40 AM(UTC)
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203406692.pdf
There is a thermal fuse on this unit for just the heater, Item 9 in "Section 1" of the parts breakdown.
Also if you have not done so turn your breaker off/on slowly a couple times.
You can loose half the line without actually tripping the breaker. The result is no heat but the main motor and timer motor both run. Better yet check that there is 240 volts at the receptacle.
If the fuse is blown be sure to clean/check the blower wheel and your vent system. Also any seals in the air path for major leaks. You are pulling air through the unit/heater, the cycling thermostat is on the blower/exhaust so if you pull in cold air in somewhere, the unit will think it is cooler than it actually is and overheat.
You will notice the fuse comes with a Hi-limit, both must be replaced.
Rather than just randomly changing parts, I would suggest you purchase a a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
