mr. g
#1 Posted : Sunday, December 19, 2010 4:23:38 AM(UTC)
mr. g
My 6 year old whirlpool dryer will not start when a cycle is selected and I press the start button. I only hear a humming noise. This just happened suddenly without any warning.
I've checked the power cord, no problems with circuit breaker. I'm hoping this is an easy fix before I make a call for for the repairman. :confused:
#2 Posted : Sunday, December 19, 2010 4:58:23 AM(UTC)
Replacement parts for WHIRLPOOL LEQ8000JQ3 29``ELECTRIC DRYER | AppliancePartsPros.com
I am assuming the hum is coming from inside the dryer.
Do you get air flow and heat?
Does it continue to hum after you release the start button?
If yes to both the above, then you may just have a broken belt and you are hearing the motor.
If no to the above then the motor cannot rotate the drum.
Try turning the drum in the correct direction to check if it is jammed or has another problem. It should turn fairly easily.
If OK
This may take two people.
With the door open push/activate the door switch.
Then push the start switch.
Rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does and the drum does not have excessive drag then odds are that the motor is toast.
mr. g
#3 Posted : Sunday, December 19, 2010 6:08:19 AM(UTC)
mr. g
Originally Posted by: denman Go to Quoted Post
If OK
The hum sounds like it's coming from the start button. It continues to hum when after I press the start button but the drum's not rotating. I didn't check the belt though.
#4 Posted : Sunday, December 19, 2010 7:43:00 AM(UTC)
OK
This unit uses a push to start relay so perhaps you are hearing relay buzz.
It could be the thermal fuse (Item 7 in Section 3).
I could not find a wiring diagram for this specific unit but on most of them the fuse is wired between the motor and the start relay contacts.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
mr. g
#5 Posted : Sunday, December 19, 2010 2:57:14 PM(UTC)
mr. g
OK
Unplug the unit.
Thanks so much! I'll give it a try and let you know how I make out.
carrlane
#6 Posted : Saturday, October 17, 2015 11:09:54 AM(UTC)
carrlane
Before checking all the thermal fuses etc. try this. Open the door, hold down the on/off door switch then push the start switch on the control pannel. On mine a chunk of the tab that the door depresses had broken off and so the door failed to activate it. Fixed it by epoxying on a piece of popsicle stick to lengthen the tab. Pretty proud of myself actually!
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
