rwb41365
#1 Posted : Monday, February 23, 2015 9:40:23 AM(UTC)
rwb41365
My maytag atlantis washer doesn't spin out, pump works to pump water, agitator seems to work just no spin. Does this mean bad Trans as I am assuming?
sidfink43
#2 Posted : Monday, February 23, 2015 3:37:40 PM(UTC)
sidfink43
Probably not the transmission. Most of the spin problems on this model are caused by a faulty thrust bearing, this part here.
Part number: AP4009132
It is an easy repair and there is a video. It will be helpful to have a helper.
fairbank56
#3 Posted : Monday, February 23, 2015 4:31:35 PM(UTC)
fairbank56
Groups: Expert
Tilt the machine back and rotate the large pulley by hand CCW while someone observes the agitator. If the agitator is going back and forth, then the transmission is bad.
Eric
GE WCSR2090D5WW washer that agitates but doesn't spin (Washer Repair)
by fljlee3 12/5/2023 10:54:18 AM(UTC)
Agitates but doesn't spin with a load (Washer Repair)
by dharar 2/17/2023 11:34:33 AM(UTC)
GE top load washer doesn't spin (Washer Repair)
by marcobot 11/4/2020 6:47:00 PM(UTC)
Washer Stops Spinning Abruptly or Doesn't Spin At All (Washer Repair)
by ggarcia 3/28/2020 9:20:13 AM(UTC)
Doesn't Spin Rapid Clicking Noise (Washer Repair)
by VBob1234 12/29/2017 4:00:51 PM(UTC)
Whirlpool Washer Sometimes Doesn't Spin on Rinse/Spin (Washer Repair)
by mbg 11/22/2017 11:49:33 AM(UTC)
Washer agitates and drains but doesn't spin. :( (Washer Repair)
by Mojube 8/2/2017 5:50:16 AM(UTC)
Roper Washer spins but doesn't spin enough water out (Washer Repair)
by tomanypups1 7/24/2016 7:14:54 AM(UTC)
Kitchen aid washer sounds like ball bearings. Doesn't spin (Washer Repair)
by LMA 1/30/2016 8:40:53 AM(UTC)
Whirlpool dryer roller, does it have bearing? it doesn't spin freely (Dryer Repair)
by tae 1/6/2016 3:30:28 PM(UTC)
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 1/2/2016 12:25:54 PM(UTC)
Dishwasher top arm doesn't spin - pump, supply, etc are all fine (Dishwasher Repair)
by wdt710paym3_broken 12/20/2015 7:29:36 AM(UTC)
Washer doesn't spin (Washer Repair)
by user21 12/8/2015 11:14:30 AM(UTC)
GE Washer agitates but doesn't spin (Washer Repair)
by InAZ 6/21/2015 12:09:09 PM(UTC)
Whirlpool washer drains but doesn't spin (Washer Repair)
by Badgerbob 6/5/2015 2:48:33 PM(UTC)
