AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool Washer Sometimes Doesn't Spin on Rinse/Spin
Seems mostly with heavy loads but tub seems locked in place when it should be spinning. If I stop the wash mode and spin the dial back to spin it will spin fine. It's like something is applying the brake? Control panel issue?
I have replaced the clutch and coupling with Appliance Parts Pro parts. I also saw where a repairman suggested to apply car brake caliper grease to the brake drum. Still have the issue.
Any suggestions welcome.
Thanks,
Mike
Thought I should add that without any clothes in it if I cycle to spin and start it I can hear a loud click like something engaging (think it's always done this?). Starts spinning then if I shut it off it stops in about one second.
Mike
Washer Repair
