I just finished replacing the freezer fan motor and when I hooked it up it worked fine. While I was trying to hook up the freezer light, the fan went off and so did the compressor. Now I have no power (no sounds) to the compressor at all. The fans won't run, but the freezer light works. Could I have shorted the unit somehow?
Jeff
THIS FORUM IS DEAD!!!!!!! |
