wysened
#1 Posted : Tuesday, October 12, 2010 11:31:19 AM(UTC)
wysened
I am working a GE fridge that does not cool. The compressor checks out ok but does not run. Where can I find a schematic? What should I check next?
#2 Posted : Tuesday, October 12, 2010 2:12:39 PM(UTC)
Are the fans inside the freezer and next to the compressor working?
Here are the breakdown diagrams and Replacement parts for General Electric PSI23MGNABB Refrigerator | AppliancePartsPros.com
wysened
#3 Posted : Tuesday, October 12, 2010 7:37:02 PM(UTC)
wysened
yep, everything works but no power to the compressor. I metered the compressor and it checks out ok. Thanks for the diagrams.
#4 Posted : Sunday, October 17, 2010 2:30:29 PM(UTC)
Sorry for the delay.
Check for 120 VAC at the connector J7-9 to the terminal J8 on the main control board. If the voltage is incorrect, replace the main control board.
- The main control board Part number: AP4436216
wysened
#5 Posted : Sunday, October 17, 2010 4:22:09 PM(UTC)
wysened
I looked at the back of the board and found a bad connection on the main relay. I soldered and it works fine.
#6 Posted : Monday, October 18, 2010 1:30:12 PM(UTC)
You are welcome. I'm glad it was such easy fix.
