I am working a GE fridge that does not cool. The compressor checks out ok but does not run. Where can I find a schematic? What should I check next?
yep, everything works but no power to the compressor. I metered the compressor and it checks out ok. Thanks for the diagrams.
Sorry for the delay. Check for 120 VAC at the connector J7-9 to the terminal J8 on the main control board. If the voltage is incorrect, replace the main control board. - The main control board Part number: AP4436216
I looked at the back of the board and found a bad connection on the main relay. I soldered and it works fine.
You are welcome. I'm glad it was such easy fix.
