randyccp
#1 Posted : Thursday, February 14, 2013 11:12:12 AM(UTC)
randyccp
There does not seem to be power to compressor. I used a voltmeter on the compressor to check. I tried a 3 in 1 hard start also. This model does not have a defrost timer. Is there a way to test if the compressor is good or should I try a new motherboard?
randyccp
#2 Posted : Thursday, February 14, 2013 11:48:22 AM(UTC)
randyccp
The evaporator fan and coil fan both are on and working. Thanks
Simon / APP Team
#3 Posted : Thursday, February 14, 2013 2:48:35 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Use the multimeter to check continuity between three compressor's pins and then to the ground. If there is continuity between all three pins and nothing to the ground - compressor is most likely good.If any of the windings are open, compressor is bad.
Locate the control board cover at the back of the fridge on the right, remove it , locate 3 wire plug on the left and J7 plug next to it.
With the fridge running check for 120VAC between the contact marked COMP and pin 9 of the J7(white).
If there is no proper voltage - replace the control board
Part number: WR55X10942
Here are the breakdown diagrams and Sealed System & Mother Board parts for GE GSS25JFMBWW - AppliancePartsPros.com
Post the results.
Simon.
randyccp
#4 Posted : Friday, February 15, 2013 5:38:41 AM(UTC)
randyccp
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
OK What do you mean by if any of the windings are open? Thank you!
Simon / APP Team
#5 Posted : Friday, February 15, 2013 8:54:45 AM(UTC)
Simon / APP Team
Groups: APP Team
There are a start and a run windings inside the compressor's motor. Open winding means - no continuity between any of the three pins (contacts).
Simon.
randyccp
#6 Posted : Tuesday, February 19, 2013 12:58:13 PM(UTC)
randyccp
Tested compressor as you said to do. It tested good. Main board showed no voltage on pins you said to check. Replaced with new board and started right up. Noticed burned solder on back of old board. Thank you!
Simon / APP Team
#7 Posted : Tuesday, February 19, 2013 1:18:49 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
No Power to Compressor (Refrigerator & Freezer Repair)
by jlarge 7/7/2014 2:26:47 PM(UTC)
No power to compressor (Refrigerator & Freezer Repair)
by tnt4him 1/18/2014 9:21:19 AM(UTC)
After power failure, no power to compressor (Refrigerator & Freezer Repair)
by tractorman44 11/25/2013 4:03:19 AM(UTC)
No power to compressor Amana Fridge (Refrigerator & Freezer Repair)
by fish 8/22/2013 7:31:05 PM(UTC)
No Power to Compressor & Evaporator Motor (Refrigerator & Freezer Repair)
by Marton 4/3/2013 8:32:58 PM(UTC)
No power to compressor or condensor fan (Refrigerator & Freezer Repair)
by David C. 6/16/2012 10:09:30 PM(UTC)
GE Side by Side No power to compressor (Refrigerator & Freezer Repair)
by wysened 10/12/2010 11:31:19 AM(UTC)
Kenmore Refrigerator no power to compressor (Refrigerator & Freezer Repair)
by Washer123 2/15/2009 3:09:44 PM(UTC)
