alan kundtz
#1 Posted : 11 years ago
alan kundtz
In late February I had to replace the compressor on my french door/bottom freezer unit (Maytag model MFI2568AEB). Since then, I have noticed that ice cream is soft/not frozen. All other items in the freezer are frozen, and new items placed in the freezer also freeze OK. Per the "troubleshooting" section of the manual, I used the temperature controls to reduce the freezer temperature to minus 2, and moved the ice cream from the upper tray to the bottom of the freezer compartment, but neither action has helped. Also, the air vents appear to be clear. Is this problem related to the new compressor? I really do not want to incur another service charge for them to say it's not their fault.
#2 Posted : 11 years ago
Post the freezer temperature.
alan kundtz
#3 Posted : 11 years ago
alan kundtz
Had to buy a freezer/refrigerator thermometer. Freezer registers 22 degrees. Refrigerator registers 38 degrees
#4 Posted : 11 years ago
Pull the back freezer panel, you will probably find a partial, light frost. If so, you have a refrigerant leak. Most are from the evaporator, best to get it fixed before the compressor is damaged by sucked in air and moisture.
Whirlpool Fridge GX5SHDXVA00 - Fridge Fine; Freezer Too Warm (Refrigerator & Freezer Repair)
by FamineLD 2 years ago
GE ZISS42DCASS - Freezer too warm (Refrigerator & Freezer Repair)
by beb123 3 years ago
Whirlpool Refridgerator GD5SHAXLQ02 - Freezer too warm (Refrigerator & Freezer Repair)
by Guest 3 years ago
Frigidaire FRT17L3FW5 freezer too warm (Refrigerator & Freezer Repair)
by danielbraus 3 years ago
Freezer too warm, fridge too cold (Refrigerator & Freezer Repair)
by Prepper 7 years ago
Fridge and freezer too warm, fans and compresser run constantly (Refrigerator & Freezer Repair)
by klide 9 years ago
Fridge and Freezer too warm (Refrigerator & Freezer Repair)
by collinsklein 9 years ago
Fridge and freezer too warm in my side by side refrigeratorld enough (Refrigerator & Freezer Repair)
by Majdo 10 years ago
Kenmore fridge AND freezer too warm (Refrigerator & Freezer Repair)
by Xuor 12 years ago
Fridge Okay, Freezer too warm, new Whirlpool (Refrigerator & Freezer Repair)
by Jody858 12 years ago
freezer too warm to freeze solid (Refrigerator & Freezer Repair)
by ckat 12 years ago
Fridge fine, Freezer too warm (Refrigerator & Freezer Repair)
by Dan Adler 13 years ago
by rockislane 13 years ago
Refrigerator and Freezer too warm (Refrigerator & Freezer Repair)
by Damian Marshall 13 years ago
Frigidaire --freezer too warm--asphalt tape from manufacturer on the freezer coils (Refrigerator & Freezer Repair)
by jpm01609 14 years ago
