mikeszutu
#1 Posted : Monday, March 24, 2014 4:31:30 PM(UTC)
mikeszutu
I think it's the control board. Just wanna confirm before making the purchase. Do you guys ship across the border :)
#2 Posted : Tuesday, March 25, 2014 1:38:40 AM(UTC)
F2 is a stuck key error so odds are that it is a control board/timer problem.
Have you tried removing power from the unit for a couple minutes to see if it will reset.
AppliancePartsPros does not ship internationally.
mikeszutu
#3 Posted : Tuesday, March 25, 2014 3:49:27 AM(UTC)
mikeszutu
I haven't bother because last Sunday the control board was giving off smoke when I trued using the ovan. Now it gives off a odor when I when I use it for anything. Figure it be smart to just replace the board.
mikeszutu
#4 Posted : Friday, March 28, 2014 5:06:49 AM(UTC)
mikeszutu
So. I replaced the control and, the code did go away but, it still omitting a burning smell. It's worse when the oven is turn on. I took off the backing of the range and see where's the smell was coming but it's hard to pin point with most of the panels off. Is there some kind of info for taking off the panels and trouble shooting?
mikeszutu
#5 Posted : Friday, March 28, 2014 5:21:41 AM(UTC)
mikeszutu
I have a feeling it's the terminal block.
WFG231LVQ0 Gas Oven F2 Code (Oven Repair (including Ranges and Cooktops))
by jwclteer 2/1/2023 12:42:38 PM(UTC)
Fixing F2 code on JDP39WOW1WW slide in range (Oven Repair (including Ranges and Cooktops))
by powerhose 10/29/2014 3:11:45 PM(UTC)
Whirlpool Gas Range F2 code (Oven Repair (including Ranges and Cooktops))
by Cookie NJ 10/10/2012 3:10:00 PM(UTC)
F2 codes on whirlpool oven (Oven Repair (including Ranges and Cooktops))
by likes2workout 6/10/2012 4:20:14 PM(UTC)
F2 Code (Washer Repair)
by cathie300c 7/31/2011 4:33:56 PM(UTC)
Whirlpool double wall oven E6 F2 code, then blank display (Oven Repair (including Ranges and Cooktops))
by jvr888 10/31/2010 7:20:02 PM(UTC)
Whirlpool oven E6 F2 code (Washer Repair)
by jendbli 8/19/2010 8:16:26 PM(UTC)
F2 code in readout annoying beep (Oven Repair (including Ranges and Cooktops))
by joe1952 3/3/2010 3:41:33 PM(UTC)
whirlpool F2 code (Oven Repair (including Ranges and Cooktops))
by bearhunter012 2/24/2010 11:43:04 AM(UTC)
Whirlpool Dbl Oven E6 F2 code (Oven Repair (including Ranges and Cooktops))
by themalones1995@gmail.com 12/29/2009 11:07:03 AM(UTC)
GE oven ELECTRIC F2 CODE (Oven Repair (including Ranges and Cooktops))
by linkqnn 11/13/2009 4:53:48 AM(UTC)
GE F2 Code (Oven Repair (including Ranges and Cooktops))
by Teager 9/11/2009 12:38:33 PM(UTC)
F2 code oven does not work (Oven Repair (including Ranges and Cooktops))
by larsenm 4/7/2009 5:26:54 PM(UTC)
F2 Code Help (Oven Repair (including Ranges and Cooktops))
by sherrylynnbrooks 2/23/2009 5:01:48 AM(UTC)
F2 code on oven/clock panel (Oven Repair (including Ranges and Cooktops))
by Bluecrab 2/15/2009 2:44:00 PM(UTC)
