Kitchen Aid electric range display panel has an F2 code. No oven touch pad keys change the F2 display and the oven will not work. Burners work fine.
First time poster. I just found your Error Code Sticky. I will check it out. Sorry in advance for not finding it sooner.
Thank you Gene. You have a great site and I have learned a lot reading through your pages.
An update of my problem. I read through the sticky on Codes I didn't see before. It was looking like the control panel. I decided to recycle the circuit breaker at the main panel before going any further. Viola, problem solved.
Keep up good work. Your blow-ups and parts breakdown are very helpful as is your guidance.
Todd.
Todd,
Thanks a lot for your good words.
