bearhunter012
#1 Posted : Wednesday, February 24, 2010 11:43:04 AM(UTC)
bearhunter012
We have whirlpool Gas range.1 year old. When the oven is turned on after a few minutes it shows a F2 code. We have called whirlpool and we installed a new control panel,(W10181986) still F2 shows up, we then installed a new oven temp sensor, still F2 shows up. Any ideas what to check?
#2 Posted : Wednesday, February 24, 2010 1:57:35 PM(UTC)
In order to provide most accurate advice we need the complete model number of the range.
bearhunter012
#3 Posted : Thursday, February 25, 2010 5:34:51 AM(UTC)
bearhunter012
model sf114pxst2
#4 Posted : Thursday, February 25, 2010 4:33:03 PM(UTC)
The part number you posted (W10181986) is for the oven sensor, which has nothing to do with this error code. If you replaced the control board, what is the part number of it?
If the range is less than a year old, it should be under the warranty.
dpkurtz807
#5 Posted : Saturday, November 6, 2010 7:29:35 AM(UTC)
dpkurtz807
I'm experiencing same issue with a Whirlpool SF114PXSB2 gas range. After about 10 minutes of pre-heating, the unit errors out with F2 and touch pad is unresponsive. The only way to clear it is to unplug for 30 seconds or so. I can plug it back in and turn the oven back on w/o the error code, but I think oven is running hot. Replaced temp sensor and control panel but issue not resolved. Sensor wiring checked out OK with multimeter. Unit is 2-3 years old.
Any ideas out there?
#6 Posted : Tuesday, November 9, 2010 12:45:44 PM(UTC)
What is the part number of the part you've replaced?
dpkurtz807
#7 Posted : Thursday, November 11, 2010 8:32:50 AM(UTC)
dpkurtz807
I've already returned the Control Panel for credit and was planning on doing the same for the sensor.
Parts installed:
AP4321499 (W10108320) Control Panel
AP4326911 (W10181986) Oven Sensor
(both ordered from appliancepartspros.com)
#8 Posted : Monday, November 15, 2010 5:49:46 PM(UTC)
There are two parts in this range with the first word "control". They are:
1./ "control panel" - the part with the key pad attached to it
and
2./ "control board" or "electronic control" which controls all oven functions.
According to the manufacturer instructions the "F2" error code means a shorted key and suggested repair is to replace the control PANEL. The part you replaced is the control BOARD. That's why it did not fix the problem.
dpkurtz807
#9 Posted : Wednesday, November 17, 2010 10:17:13 AM(UTC)
dpkurtz807
Thank you for the information.
That's the problem with a do-it-yourselfer like me... :o
