I think it's the control board. Just wanna confirm before making the purchase. Do you guys ship across the border :)
F2 is a stuck key error so odds are that it is a control board/timer problem.
Have you tried removing power from the unit for a couple minutes to see if it will reset.
AppliancePartsPros does not ship internationally. |
THIS FORUM IS DEAD!!!!!!! |
I haven't bother because last Sunday the control board was giving off smoke when I trued using the ovan. Now it gives off a odor when I when I use it for anything. Figure it be smart to just replace the board.
So. I replaced the control and, the code did go away but, it still omitting a burning smell. It's worse when the oven is turn on. I took off the backing of the range and see where's the smell was coming but it's hard to pin point with most of the panels off. Is there some kind of info for taking off the panels and trouble shooting?
I have a feeling it's the terminal block.
