mikeszutu
#1 Posted : 11 years ago
mikeszutu
I think it's the control board. Just wanna confirm before making the purchase. Do you guys ship across the border :)
#2 Posted : 11 years ago
F2 is a stuck key error so odds are that it is a control board/timer problem.
Have you tried removing power from the unit for a couple minutes to see if it will reset.
AppliancePartsPros does not ship internationally.
mikeszutu
#3 Posted : 11 years ago
mikeszutu
I haven't bother because last Sunday the control board was giving off smoke when I trued using the ovan. Now it gives off a odor when I when I use it for anything. Figure it be smart to just replace the board.
mikeszutu
#4 Posted : 11 years ago
mikeszutu
So. I replaced the control and, the code did go away but, it still omitting a burning smell. It's worse when the oven is turn on. I took off the backing of the range and see where's the smell was coming but it's hard to pin point with most of the panels off. Is there some kind of info for taking off the panels and trouble shooting?
mikeszutu
#5 Posted : 11 years ago
mikeszutu
I have a feeling it's the terminal block.
WFG231LVQ0 Gas Oven F2 Code (Oven Repair (including Ranges and Cooktops))
by jwclteer 2 years ago
Fixing F2 code on JDP39WOW1WW slide in range (Oven Repair (including Ranges and Cooktops))
by powerhose 10 years ago
Whirlpool Gas Range F2 code (Oven Repair (including Ranges and Cooktops))
by Cookie NJ 12 years ago
F2 codes on whirlpool oven (Oven Repair (including Ranges and Cooktops))
by likes2workout 13 years ago
F2 Code (Washer Repair)
by cathie300c 14 years ago
Whirlpool double wall oven E6 F2 code, then blank display (Oven Repair (including Ranges and Cooktops))
by jvr888 14 years ago
Whirlpool oven E6 F2 code (Washer Repair)
by jendbli 15 years ago
F2 code in readout annoying beep (Oven Repair (including Ranges and Cooktops))
by joe1952 15 years ago
whirlpool F2 code (Oven Repair (including Ranges and Cooktops))
by bearhunter012 15 years ago
Whirlpool Dbl Oven E6 F2 code (Oven Repair (including Ranges and Cooktops))
by themalones1995@gmail.com 15 years ago
GE oven ELECTRIC F2 CODE (Oven Repair (including Ranges and Cooktops))
by linkqnn 15 years ago
GE F2 Code (Oven Repair (including Ranges and Cooktops))
by Teager 15 years ago
F2 code oven does not work (Oven Repair (including Ranges and Cooktops))
by larsenm 16 years ago
F2 Code Help (Oven Repair (including Ranges and Cooktops))
by sherrylynnbrooks 16 years ago
F2 code on oven/clock panel (Oven Repair (including Ranges and Cooktops))
by Bluecrab 16 years ago
