2 Pages<12
#11 Posted : Friday, March 14, 2014 3:11:49 AM(UTC)
[COLOR="Blue"]I found a temperature control at Sears, is that the same thing that you previously mentioned as the control thermostat?[/COLOR]
Below is the control thermostat I was referring to. It controls the temperature in the freezer. Click on the picture for more info about the parts.
Part number: AP3964661
[COLOR="Blue"]I also found a defrost control thermostat, would either of these be the part that you mentioned?[/COLOR]
No.
FYI The defrost thermostat is in the freezer. It is clipped onto the top of the evaporator coils. It's function is to open just above freezing (when the ice has melted off the coils), killing power to the defrost heater. This prevents the defrost from putting too much heat into the freezer.
Confused!!! Trying to wire up a replacement motor for Kenmore 110.86983800 (Dryer Repair)
by Guest 1/17/2024 10:02:08 AM(UTC)
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 12/4/2017 9:24:14 AM(UTC)
F 28 code - confused by dignostics (Dryer Repair)
by dpollock 3/22/2017 11:35:46 AM(UTC)
GE fridge is confused! (Refrigerator & Freezer Repair)
by gcrashm 3/1/2017 5:28:13 PM(UTC)
I'm so confused about the model # (Refrigerator & Freezer Repair)
by g9672001 8/17/2013 4:19:17 PM(UTC)
Confused (Oven Repair (including Ranges and Cooktops))
by ovenman 12/13/2012 7:38:00 AM(UTC)
Confused on Washer Timer (Washer Repair)
by lfreng 10/24/2012 4:30:17 PM(UTC)
Confused GE Profile Washer!! HELP (Washer Repair)
by luta46 9/24/2012 5:50:27 PM(UTC)
Confused, is cardboard under refrigerator packing? (Refrigerator & Freezer Repair)
by vrineer 1/29/2012 9:39:26 AM(UTC)
Frigidaire Laundry Center confused (Washer Repair)
by rodrigo_umana 10/26/2010 6:54:12 PM(UTC)
confused and frustrated (Dishwasher Repair)
by Florenrose 5/8/2010 3:19:00 PM(UTC)
by jefferybeecher73@gmail.co 2/18/2010 6:47:04 PM(UTC)
Still confused Re: "Glide" (Dryer Repair)
by 5december 10/7/2008 9:09:42 PM(UTC)
by Mike Clifford 9/29/2008 10:10:13 AM(UTC)
Oven is confused about set temperature (Oven Repair (including Ranges and Cooktops))
by jhuff 8/28/2008 12:43:01 PM(UTC)
2 Pages<12
