Bill R
#1 Posted : Monday, May 4, 2009 10:03:17 AM(UTC)
Bill R
My gas dryer has an ignition problem. The dryer will start every time, and ignite the burner. However, after a couple of minutes of running it will stop burning, and attempt to re-light after a minute or two. It will attempt to light every minute or so until it finally decides to re-light. (maybe 4 or 5 attempts, before it finally re-lights.)
Where should I start troubleshooting ?
applianceman
#2 Posted : Monday, May 4, 2009 2:50:34 PM(UTC)
applianceman
If it lights one time I wouldn’t think that the igniter is bad or the gas supply. the first thing I would look at is the coils on the gas valve. When it stops working does the igniter glow and then turn off? If so the coils should release gas at the same time as the igniter cuts off. Gas Dryer Repair Guide
Bill R
#3 Posted : Tuesday, May 5, 2009 4:04:07 AM(UTC)
Bill R
So if it is the coils, how do I Prove that it is not the valve itself ?
applianceman
#4 Posted : Tuesday, May 5, 2009 1:31:30 PM(UTC)
applianceman
It is likely that the coils are opening when they get hot. I am not saying it can’t be the valve but just that the coils are more likely. Also the problem is intermitting so it can be hard to confirm.
Knocking noise from my ge gas dryer. (Dryer Repair)
by Lougaal 2/16/2023 9:40:08 AM(UTC)
GE gas dryer rattling (Dryer Repair)
by johno1947 4/24/2017 4:11:51 PM(UTC)
GE gas dryer heats for a few minutes, then goes cold (Dryer Repair)
by swapped 9/24/2015 9:31:14 AM(UTC)
Weird, GE gas dryer not keep running (Dryer Repair)
by techlover 8/6/2015 8:14:16 AM(UTC)
GE Gas Dryer Igniter Glows but No Flame (Dryer Repair)
by kwillindy 5/4/2015 9:21:49 AM(UTC)
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 1/23/2015 5:38:59 PM(UTC)
GE gas dryer on/off button (Dryer Repair)
by phillipj 1/10/2015 3:00:35 PM(UTC)
GE Gas dryer (Dryer Repair)
by cstellar 12/22/2014 10:46:32 AM(UTC)
GE Gas Dryer Error Code E01 & Stopped intermittently (Dryer Repair)
by bhurlbert 4/21/2013 5:43:49 PM(UTC)
GE gas dryer won't stay on (Dryer Repair)
by Bearjohnson 2/26/2013 10:36:11 PM(UTC)
ge gas dryer trips fuse after installing ignitor (Dryer Repair)
by lucyfoot 2/25/2013 3:19:07 PM(UTC)
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
ge gas dryer no heat (Dryer Repair)
by mdelgiu1 11/7/2012 1:23:14 AM(UTC)
GE Gas Dryer - Drum Won't Turn / Locked Up (Dryer Repair)
by roma1625 10/31/2012 9:52:33 AM(UTC)
Ge gas dryer no heat (Dryer Repair)
by moby2000 10/25/2012 9:04:28 AM(UTC)
